P0341 2007 Chevy HHR 2.2L
Old Dec 5, 2021 | 12:46 PM
redslim73's Avatar
You guys are awesome.Thanks for all your insight and help!Now shipping the motor to y'all😁 Thx really though!
Old Dec 5, 2021 | 01:02 PM
Sure, I’ll fix it up here and send it to you soon! The shipping might be a dealbreaker! 😃
Old Jan 4, 2022 | 06:07 PM
redslim73's Avatar
2007 Chevy HHR 2.2L Won't start!
Did Timing Chain and Water Pump replacement!Put the battery back in(fully charged),went to crank the car and the lights went to flickering,the dashboard too!A lock image popped up in the left corner of da*****he key got stuck in the ignition as well,and the doors would unlock but not the trunk!Any help would be greatly appreciated!
Old Jan 4, 2022 | 06:21 PM
Inspect the battery cable clamps, they have been known to crack. Check the ground cable for tightness and corrosion.
The positive cable runs from the battery, then to the underhood fuse block, then to the starter, then to the alternator. Check all these connection points for tightness and corrosion.
Take the battery to the auto parts store for a free load test.
Old Jan 4, 2022 | 06:43 PM
Sounds to me like a dead cell or 2 in the battery, been there, had to buy a new battery. Do inspect the cable ends as RJ posted above
Old Jan 4, 2022 | 09:25 PM
  #26
redslim73's Avatar
Its getting no lights,radio,nothing!Won't even crank!Checked everything!Bout ready to throw in a wood chipper!
Old Jan 5, 2022 | 07:52 AM
  #27
Lonwane's Avatar
No lights means power is not getting to them.
Start at the battery with a volt meter and start checking ALL connections.
Find out where it stops. Investigate the last known power measurement. There's your problem.
Old Jan 5, 2022 | 07:56 AM
  #28
redslim73's Avatar
Thank you and will do soon as I get home from work!
Old Jan 5, 2022 | 08:18 AM
  #29
Check the connections on the under hood fuse box. The security light and key lock happen with dead battery; either it is dead or disconnected.
even check the forehead slapper stuff; like polarity of the battery. There is a solid wire from the battery to the under hood fuse box.
Old Jan 5, 2022 | 01:20 PM
  #30
redslim73's Avatar
Nothing lit up after the first initial try after putting the battery back in.Will try everything.Ordered a voltage meter this morning so it should be there when I get home!Than for everything you guys have helped me with!
