P0341 2007 Chevy HHR 2.2L
Old Jan 9, 2022 | 10:47 AM
  #31
redslim73's Avatar
Car won't start
2007 Chevy Hhr 2.2l =Replaced timing chain and water pump.Put everything back together,now it won't start!Ran a scan,no problems detected!What could be keeping it from starting?
Old Jan 9, 2022 | 11:13 AM
  #32
Timing off, camshafts not in time with the crankshaft.
explain why you changed the timing chain, did it break? Skip a tooth? Front guide broken?
If so, the pistons could have hit the valves and bent some of them.
Old Jan 9, 2022 | 11:19 AM
  #33
You already have another thread about this same issue. Go back to that thread. There were suggestions posted.
  #34
redslim73's Avatar
The black guide was broken when I took off the timing cover,as well as the guide at the top was split where the chain was rubbing against it!
Old Jan 9, 2022 | 11:56 AM
  #35
All 3 threads merged.
Old Jan 9, 2022 | 12:10 PM
  #36
Then it is possible either there is a bent valve or two, the timing marks on the chain are off or, something didn’t get reconnected
Old Jan 9, 2022 | 07:04 PM
  #37
redslim73's Avatar
How would I know a valve is bent?
Old Jan 9, 2022 | 07:12 PM
  #38
So, is the engine turning over and not starting or is the battery still dead?
Old Jan 9, 2022 | 07:13 PM
  #39
redslim73's Avatar
Engine is turning over and battery is fully charged(12.56V)
Old Jan 9, 2022 | 07:14 PM
  #40
redslim73's Avatar
Not starting!
