P0449, 2007 hhr ls
I get a P0449,code it is not the solenoid, it's the long chassis harness that go from the chassis to the short jumper harness that goes to the solenoid. It has a blank white tag, so I don't have the part number, anyone out there have a 2007 HHR LS that can give me the number? Thanks
You would be very smart if you changed your user name; it is inviting problems to publish your email. Sroll to the bottom of the page and click on "contact us" then click on change user name.
I am, not sure what wire you mean. If the valve has been replaced there is an adapter between the car harness and the valve. |
My last name is Bombardier, I use that user name it's part of my name, I went to a scrap yard for the long harness. Thanks
sent a request to change username. |
