Chevy HHR Network
-   -   P0449 and p0455 (https://www.chevyhhr.net/forums/problems-service-repairs-42/p0449-p0455-65105/)
Joe Reed Feb 21, 2022 11:42 AM
P0449 and p0455
My CEL cam on in my 2008 ls panel... the codes are 449 and 455... i have changed the vent solenoid and the gas cap with no luck... any idea where i should go from here or what i could so to figure this out??
Oldblue Feb 21, 2022 01:45 PM
EVAP Vent valve under the rear of the car
https://www.obd-codes.com/p0449
As you said gas cap, or other leak in EVAP system, check fuel vapour line up above the rear axle and try to blow through the purge valve under the hood, it should be closed and not allow air in either direction
https://www.obd-codes.com/p0455
donbrew Feb 21, 2022 02:01 PM
Did you check the fuse? Under hood #64
Joe Reed Feb 21, 2022 02:49 PM
you my friend are a legend!! how did i not see that fuse... its blow... however im waiting for a purge solenoid so im gunna replace that anyway... if that fuse fixes this i owe you a coffee or something!!
donbrew Feb 21, 2022 02:58 PM
It would be a good idea to find out why it blew.
Joe Reed Feb 21, 2022 03:02 PM
well all last summer the light would come and go... so im thinking the vent valve was packing its bags then..
Joe Reed Feb 21, 2022 05:23 PM
so after changing fuse and the purge the light went out for about 2 mins and the light came back on for p0449
donbrew Feb 21, 2022 07:49 PM
The wires have been known to fray.
RJ_RS_SS_350 Feb 21, 2022 07:55 PM
So did the fuse blow again?
PulpFriction Feb 22, 2022 08:48 AM
Did both codes arrive at the same time or did you ignore a CEL for awhile?
If the fuse blew again it could be a short (duh.) If it didn’t you could try clearing the codes, or did you already do that?
I don’t see how you have an explanation for P0455 yet tho.
The good news is a large leak might be easily found with a smoke test. I have a nagging P0442 small leak, too small for a smoke test to detect, apparently.
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0455 Evaporative Emission (EVAP) System Large Leak
