P0700 and P0751, wont shift into high gear, shifts hard into lower ones
Old Sep 26, 2012 | 11:16 AM
oneton's Avatar
Did you have the new TCM programed to your vin. after it was installed. It has to be programed or it still won't shift.
Old Sep 26, 2012 | 11:45 AM
ImNewHere's Avatar
Yes, they installed and programmed it in the vehicle.
Old Sep 27, 2012 | 08:22 AM
Originally Posted by ImNewHere
I am about to try some other GM dealers sicne the one I normally use has not gotten back to me for the past 3 days for a simple quote.
I would still call other dealerships to compare prices as each dealership is independently owned and operated.
Old Sep 27, 2012 | 10:55 AM
ImNewHere's Avatar
I did and they are the cheapest. It's at the dealer and being done right now.
Old Oct 5, 2012 | 06:29 PM
ImNewHere's Avatar
Fixed now. Ended up costing a little over 800 dollars, but at least they changed the filter while in there too even though the solenoid wasn't under that pan.
Old Jul 31, 2014 | 07:22 PM
gdgygg426's Avatar
Gdgygg426
Originally Posted by murdog94
Well P0700 is a Transmission Control System Malfunction, and P0751 is stuck solenoid A Performance. Seems that you have either a valve body issue OR the TCM is crapping out as said.
I would have a reputable tranny shop at least diagnose which is the issue. The dealer is more expensive, and will want to fully replace the tranny rather than a cheaper rebuild.
So what cost of repair are we speaking of?
sklute
May 17, 2015 02:27 PM
FMHHR
Apr 28, 2014 09:30 PM
06gray2ltHHR
Feb 17, 2011 06:24 AM
uglyjim
Jan 15, 2011 06:20 PM
Biker Ken
Dec 31, 2010 07:17 PM
