P1174
Old Jan 2, 2019 | 05:59 PM
Old Jan 2, 2019 | 08:20 PM
hurst2001's Avatar
Originally Posted by donbrew
Could be #1 O2 sensor.
The way thy work is by comparing ambient air to combustion air; it gets the ambient air sample from the tiny gap between the wire and the entry hole. If that hole gets clogged things get wacky.
Could be flex pipe.
Could be any tiny vacuum leak including injector O-rings.
thanks don and blue
I’m going to take it to the shop for plugs and clean the map sensor have them check for leaks . I usually do my own maintenance but it’s too dam cold here in Chicago no garage.. I will let you guys know ..
jdevries
Jan 2, 2015 12:09 PM
justinrsetzer
May 1, 2012 02:44 PM
Tony_SS
Jan 10, 2011 12:18 PM
sunbound
Aug 29, 2008 11:07 AM
