Chevy HHR Network
-   -   p1174 -Fuel Trim Cylinder Balance (https://www.chevyhhr.net/forums/problems-service-repairs-42/p1174-fuel-trim-cylinder-balance-43947/)
SmootHHR Jan 15, 2013 12:25 PM
:duh::wtf: so....the CEL is back on. p1174 is now accompanied by p0172 and p0304. I'm about to lose my mind chasing this freaking CEL. As stated before, my buddy reprogrammed the ecu before I installed the injectors. Said he'd try it again now that I've got the new one's in. Will see how that goes.
p0172 - fuel trim bank one condition
00304 - cylinder misfire detected, cylinder #4
p1174 - fuel trim cylinder balance
The plugs only have about 45k on them...hoping the coil packs aren't bad.
IgottaWoody Jan 15, 2013 01:48 PM
if you look on the threaded end of the link, under the rubber cup, you'll find a wrench flat area where you put the wrench to hold it while taking nut off..
SmootHHR Jan 15, 2013 03:40 PM
much appreciated...wish I had that info on Friday:lol:
SmootHHR Jan 16, 2013 06:08 PM
Car fell on it's face today...surprised me. Probably looking at a coil pack. Yucky
SmootHHR Feb 14, 2013 12:21 PM
Well, didn't need a coil pack. Changed the #4 plug and the misfire hasn't returned..nor has the p1174. I am, however, still getting the p0172 from time to time. Wish I could pin point what was wrong as that friggin light makes me crazy!
hurst2001 Dec 26, 2013 11:34 PM
I am about to do this but a few questions i got a 2.2 2007 hhr and i am getting the code p0304 so i replaced the coil and plug for starters and still came back so next to test the injectors mind it has 176000 miles on her tried seafoam help a little bit but know leaning toward injectors , so can you pull your neg cable off for five min, to reset the ecu and install injectors or you have to have it programed ? were do you get the program? also i am going with the ac delco injectors 217-2907 any inputs thanks
donbrew Dec 27, 2013 01:33 PM
Just disconnecting the bat should do it. You just need the ECU to forget it's learnin' so it can re-learn how you drive with the new injector in place.
CR Dave Apr 3, 2014 12:26 PM
Bit of an update: Its been awhile since I've been on here. The light was on for a long time. I meant to change plugs, etc, then my Daughter went to university in Victoria plus a surgery for me in December- about 200 miles away and with all the high speed driving, the light goes out and comes back on while doing city driving. The next road trip clears it again. What a car! nearly 100,000km on it. Very few problems with it. Now the recall. BTW I see Duck Commander is sponsoring this week's NASCAR race.
donbrew Apr 3, 2014 12:53 PM
Look for "pending" codes, I would bet that you have the same problem I had/have. It shows up in city driving, especially if you get up to 4th gear then abruptly stop. Most likely cause is either EVAP purge solenoid and or flange gasket, could be a small vacuum leak anywhere from the intake manifold to the #2 O2 sensor.
novadude Oct 30, 2014 05:11 PM
Just had my first P1174, car seems to run fine, idle is a little high sometimes, just cleared it and figure i will see what happens, but, i had my ignition switch replaced under recall just 2 months ago, havent been to the dealer since the clunking started back when i had 40k, it has 106k now, hmmm
