p1174 and p1516 codes
driving home tonight these codes popped up. ran fine, coolant temp is 196, outside temp is 6 degrees. I'm thinking corroded connectors?? maybe able to take a peek in the morning. should be about 10 above (?)
Possible causes P1174
Clogged Fuel Injectors Faulty Oxygen sensor Ignition problem Fuel injection problem Engine mechanical condition Possible causes P1516 Faulty Throttle Actuator Control (TAC) module Throttle Actuator Control (TAC) module harness is open or shorted Throttle Actuator Control (TAC) module circuit poor electrical connection Check Throttle Actuator Control (TAC) module connector for water Binding or bent throttle plate-failed throttle body Check the wiring harnesses for damaged connectors bent pins, corrosion. |
P1516 inhibits P1174 from running. So the throttle is the problem.
A low voltage condition may set P1516. I would start with battery voltage then inspect the throttle harness connector. Look at the butterfly, these are bad: is it not in the rest position is it binding is it moving freely without resistance is it filthy |
And remember, do not move that throttle body butterfly plate manually! The plastic gears will strip and there’s no fixing that! Just replace the throttle body!
Perhaps hellshotrod has one he can send you, send him a PM |
good to know! I' ll see what I can see. Battery was installed 7 months ago (from the receipt) only 7 degrees out so I only checked the electrical connector, nothing bent but I did spray it down with contact cleaner. more when it warms up outside. seems intermittant so I would gues electrical.
A dirty throttle body can present as intermittent in this cold.
a guy at work had the same issue, only a bit worse on his mom's caddy. it would only act up when it got below 30 degrees. he ended up replacing the throttle body.
The grease in the works can get too stiff in the cold.
And that grease after all these years can get dried out and clumpy!
i have seen videos mentioning a relearn sequence when the throttle body is replaced. is that something that can be done 'backyard mechanic' style or does it need a trip to the dealership?
