Passenger Side Blend Door Actuator
Hi everyone. I'm new to the group and hope I can find someone with some
Experience with a problem that crept up. I've had a 2009 HHR since, well 2009. Recently the thumping inside the dash came up. I popped out the glove box and located the source: the actuator to the right of the vent door. It is now stuck in recirculate mode which is fine, but I'd like to replace this part. I received a quote for 700$ and that makes me want to just live with it! The part is less than 50 bucks but I am concerned about reaching the screws that hold the actuator in. Has anyone done the passenger side blend door before? If so, how was getting the old one out and the new one in? Looks pretty tight in there for tools. The mechanic says he'll take the whole dash out but that seems a bit much for a plastic part that goes in under 60k miles. Thanks! John 2009 HHR 58k |
1 Attachment(s)
Welcome to the site :smile:
I think you are talking about the recirculation actuator that is number 4 in the picture. |
It looks like the dash has to be removed if it's you need the recirculation actuator.
There is a descant step by step with pic's on the autozone web site if you want to try this project. |
Thank you!
Originally Posted by Lucky
(Post 751856)
Thanks
(Post 751857)
you'll need a 5.5 mm socket and a 1/4 inch drive ratchet, I just changed the one on my '03 Sunfire GT, took 10 minutes and some ackward aerobics to get my hand up there!
Originally Posted by Oldblue
(Post 752292)
Hi. I have a 2007 HHR that makes a clicking noise for the first 5 seconds after starting it under the passenger side air bag. I have taken the glove compartment out and a person at a parts start said it was the blend door actuator. He has an 2007 HHR himself and had the same problem. It sits high up in the dash and am trying to figure the best way to get to it. So far, I have not found anything in Chilton's or by searching on line for videos or diagrams. I am looking for suggestions.
Thanks, Deborah |
If it's on the far passenger side then your talking about the recirculation Actuator.
Autozones web site has some fairly good step by step diagrams. |
It sits up high, right under where the passenger air bag sits. The guy at the parts store said it was the blend door actuator because he had one go bad and he used to own a repair shop. I know there is 3 to choose one, but when he put his hand up there, he was able to stop the clicking. I am looking for a diagram on the best way to access this area. I am trying to decide if this is something I can fix myself or if I am over my head.
Thanks for your help. |
