Pins/connectors needed for pcm?
I made a post some time ago about me fighting with the reduced engine power p2135? Code.
since then I have: replaced the TB(thought you could take them apart lol) replaced the Pedal position sensor Replaced the plug in on the actual TB at times I can’t take a 5 min drive without having to reset codes atleast 30 times to make it to my destination If I unplug the pcm, un plug the tb, jiggle some wires car drives perfect for hundreds of miles. Then it starts back and keeps getting worse until I unplug and clean the plugs again.. I have tugged on the 6? Wires that lead from the TB connector into the pcm connector and felt no noticeable pull within them to make me think wires are broken. i would still like to replace these entire wires. Does anyone have a link where I can find the replacement connectors that feeds into the pcm connector? i found a crimp tool on amazon and found various connectors but just want to make sure I buy the correct ones. thank you hhr forum -Phil |
Usually it is the pin in the connector has pushed out the back.
P2135 has nothing to do with the Accelerator Pedal Position sensor. There are 2 Throttle Position sensors; 1 measures how open, the other measures how closed the throttle is. When the ECM/PCM senses that they don't agree it throws the code. What year/model/engine, before I start spending time. |
I kinda knew there were two sensors. I thought one was the TB and the other was the pedal? Is that wrong? my car is a 2007 2.2 auto LT? I think i love the car, I have a 15 ram diesel, 2 srt4, but the hhr really is my daily drive it more than any of the vehicles I have combined. |
From what I've read the two sensors A and B are the throttle pedal and the throttle body.
If one doesn't agree with the other passed 2 seconds a code is thrown. Google the code, it seemed to be a common problem with certain GM vehicles. |
There are 2 circuits, the TB has 2 sensors and the pedal has 2 sensors. Neither the TB ot the pedal speaks directly to the other. P2135 checks that the 2 sensors in the TB agree with each other; Is the open angle complimentary to the closed angle?
I thought I was rather eloquent in my earlier description. The TSB on the subject describes pins pushing out the back side of the ECM connector. pins 57 & 59 on the C2 connector are for the throttle position sensor signals, however, there are also a 5 V ref and a low ref. https://cimg7.ibsrv.net/gimg/www.che...7bea61c7de.png https://cimg9.ibsrv.net/gimg/www.che...f2763e5b19.png |
Now that is some quality information!!!! Thank you |
Sorry for my incomplete information.
Tsb
Originally Posted by donbrew
(Post 844473)
The difference between the two pins labeled 33067-000x is one is for 22 ga and the other is for 18-20ga. I have thousands of the 18-20ga pins in stock. If you can't find them, 25 cents each plus shipping. I have the 0006 version which is the reverse wound 0005, Different windings are used in different kinds of crimping presses.
Pins
Originally Posted by lazaino
(Post 953792)
Can I just replace the connector plug instead of replacing the pins? Or are the pins in the other side of the connection? |
| All times are GMT -5. The time now is 08:54 AM. |
