Please Help
Old Oct 16, 2021 | 11:11 AM
jjohns10's Avatar
Originally Posted by donbrew
Be sure to use AC/Delco 41-103 iridium spark plugs, they should be changed at 100,000 miles. Don't try to gap them!
Do a compression/leak down test.
Thanks i am currently changing the spark plugs myself. hopefully this works
Old Oct 16, 2021 | 11:47 AM
jjohns10's Avatar
Oil In the spark plug cylinder
2/4 of my spark plug tubes are full of oil. would this cause the car not to start ?
Old Oct 16, 2021 | 11:49 AM
Depends on how the got filled.
Old Oct 16, 2021 | 01:26 PM
jjohns10's Avatar
changed all spark plugs, still not starting. the fuel pump fuse is blown but i just changed it. what
could be the cause?
Old Oct 16, 2021 | 02:06 PM
Trace the wires for the fuel pump, see if there's any damage.
Old Oct 16, 2021 | 03:10 PM
Yup, what he said!^^^^
Old Oct 16, 2021 | 03:55 PM
If the fuse blew the mechanic did something wrong.
Old Oct 16, 2021 | 04:07 PM
The fuse blew before the repair, and now again after the repair. So the problem still exists, the mechanic didn't diagnose correctly, take it back. He shouldn't have charged you for the fuel pump work.
Old Oct 24, 2021 | 10:28 AM
jjohns10's Avatar
Update
So the fuel pump that was put in was for a newer model and was bigger than my original one. Which was why the fuse kept blowing out, i had to put in a larger amp fuse. I put in a 25 instead of a 15 and it seems to be working fine for now. Thanks for all your help.
Old Oct 24, 2021 | 11:32 AM
Why not install the correct pump? Mechanic is an idiot?
