please help. car wont start after replacing shift assembly
Two weeks ago the shifter broke and was stuck in neutral or drive and before that the key would not release. So I replaced to shift assembly and now the car wont start. It doesnt sound like its trying to turn over and also tried to jump start it and nothing. The check engine light is on but have noway to get the reading. Ive checked to fuse that generally blows if you dont jump it right and its oka.
Please explain what you mean when you say it "doesn't sound like it tries to turn over" - it either turns over or doesn't. Also explain what you mean about when jumping it - "nothing"?
The cel lights when the engine is running - are you saying that it was lit before you took things apart for the repair?
Thank you so much for trying to assest me whopper i ended up finding out the problem. The shift cable popped out of the shifter.wow do i feel dumb at that.im glad to find a forum for the hhr that has useful info.
One may be tied to the brake pedal lock that requires you to depress it to shift out of park. I wish I would have taken pictures, I just built a new shaft out of Delron instead of the cheap plastic and rebuilt it myself. The hardest part is taking the console apart!!
Tim
sklute
May 17, 2015 02:27 PM
Decoteau
Sep 5, 2013 05:18 PM
johncin13
Nov 26, 2010 06:24 PM
