Chevy HHR Network
-   -   Please help, F23 trouble (https://www.chevyhhr.net/forums/problems-service-repairs-42/please-help-f23-trouble-67856/)
Easton06 Feb 3, 2026 07:34 PM
Hello, everyone I just bought a 2006 hhr LS in orange.
It's the basic 2.2 ecotech and the F23 trans. I bought it for 1400 bucks with around a 100000 miles on it. The issue I'm having is it was grinding in third and fourth gear. I found out that the transmission fluid was very low So I filled it completely with new fluid. Now, since that's all done I drove it again and it only grinds when I let off the clutch and it still won't go into third or fourth. And fifth is non-existent. First second and reverse work good. And For context, the last owner replaced the clutch and had these issues in parked it. I am really hoping it's not a synchro issue but alas I'm here. Thanks.
https://cimg4.ibsrv.net/gimg/www.che...b4a3405b56.jpg
Easton06 Feb 3, 2026 07:36 PM
Also I removed the cables and am buying new ones. Also I'll probably Get the whole new short shifter kit just to replace as much plastic as I can. The shifter cup is also pretty worn.
Oldblue Feb 4, 2026 06:49 AM
Those might resolve the issues, let us know after you replace them.
Did you drain out the remaining old transmission fluid? Then fill with fresh fluid?
Easton06 Feb 4, 2026 01:44 PM
I did replace with new fluid, the engine is much happier now
Easton06 Feb 4, 2026 01:47 PM
https://cimg7.ibsrv.net/gimg/www.che...5eb437c630.jpg
This was how much fluid. I overfilled it with dex 3 at 2.6 quarts. Hopefully this low fluid didn't ruin the syncros
donbrew Feb 4, 2026 02:23 PM
Doesn't make much difference but, GM upgraded the recommendation to dexron VI.
Where did the fluid go?
Easton06 Feb 4, 2026 02:25 PM
I have a feeling that the first owners never added fluid. It's also from New Mexico. And I'm here in Northern California, and it's been in really hot areas, so I have a feeling the fluid evaporated maybe
Easton06 Feb 4, 2026 02:26 PM
To be honest, I might just get a new transmission from DF kit car. No one wants to work on it up here.
Oldblue Feb 4, 2026 03:46 PM
Install those shift cables you ordered and go from there.
Easton06 Feb 4, 2026 03:49 PM
That's the plan ill keep in touch 🤞
