possible oil leak?
Old 08-04-2013, 12:05 AM
hurst2001's Avatar
Im so sorry guys it is the crankshaft seal it is right behind the crank pulley . my bad anyway it must had been leaking for sometime and notice it when putting on the quick struts ..I used dino oil for most of its life and then switch to a synthetic blend a month ago and can see oil on the bottom shroud on the passenger side were you can pop it off if you were changing the serpentine belt is ... any input on repair if anybody did one? thanks
hurst2001 is offline
Old 08-04-2013, 11:24 AM
Technical Moderator
If it is only weeping, don't agonize about it. If it is dripping steadily, you may not be able to torque the the new balancer bolt back on with home tools. It should not take a good mechanic more than an hour labor.
Type/brand/style of oil is irrelevant. It's a wear thing, you can try one of those seal treatment chemicals if it's weeping, but don't expect results.
donbrew is offline
Old 08-04-2013, 04:27 PM
hurst2001's Avatar
thanks don brew but its weeping for sometime and i am going to replace the seal fel pro and timkin make them,anyways. I heard that a product called {At205} is the best for this use scott kilmer on you tube recommends this stuff...thanks
Old 08-04-2013, 04:45 PM
Technical Moderator
The bolt on the harmonic balancer needs to be replaced and the torque spec is 74 Ft.Lb. + 125 degrees. I don't know how you would hold the crankshaft.
donbrew is offline
1970judge
08-14-2015 05:47 PM
gschroed
01-29-2014 07:24 AM
HHR_style
05-03-2010 01:04 AM
blomb
07-03-2008 11:30 AM
pobryne
06-05-2008 09:47 PM
Quick Reply: possible oil leak?
