Possibly fuel pressure problems
Old Sep 1, 2020 | 09:04 AM
Lonwane's Avatar
Toughie sometimes exhibits these same charecteristics.
He will fail to start on the first try but never on the second.
I attribute this to the pressure check valve in the fuel pump.
I have experienced the rough start then an rpm rise then a return to normal.
Could that be a fuel pressure issue also?
Old Sep 1, 2020 | 09:54 AM
Yes. A weak or failing fuel pump or faulty injectors.
Old Sep 1, 2020 | 10:22 AM
Lonwane's Avatar
Thanx
I will add that to my list of repairs
Old Sep 1, 2020 | 11:17 AM
Rent a fuel pressure tester, the fuel pump pressure should be 50 to 65 psi
Old Sep 2, 2020 | 02:30 PM
Lonwane's Avatar
Just want to verify that Toughie does not run rough just an occasional rough start.
He runs and shifts smooth.
I'm still changing the chains, guides, seals, gaskets, water pump, spark plugs, struts, sway bar bushings, themostat and hoses at 175k.
Gotta love these trucklets.
Mrjustfixit
May 7, 2020 06:10 AM
Ijazzu
May 5, 2015 01:29 PM
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
car nut
Dec 3, 2013 06:32 PM
Paina
Jun 28, 2013 04:49 PM
