Power brake and dashboard lights
Old Jul 28, 2017 | 05:15 PM
From what I can tell from this pic from the TSB it is just near the starter with a tube a TEE in the vac line.
Like I said there are photos of the install in the TSB.
I am making a wild guess that the motor has fried causing a voltage drain while it is trying to do it's job, then when the cut-off happens the dash lights go back to normal.
Old Jul 28, 2017 | 05:24 PM
Hey Don.
Every thing I've seen and read on this site shows the pump mounted by the oil pan/block seam. Between the radiator and engine.
Most likely can't clearly see the pump from above.
It mounts somewhere close to here(yellow X's) where I added my charge pipe brace.
Disregard the red circle.
I agree, looking at drummerboy's thread, looks to be between the starter and the AC compressor. Just pulled up onto the ramps to try to determine where it would be if I had one. Probably very difficult to spot from above.
But Geeze, you could follow the hose that runs between the brake booster and the intake manifold. If there is a Tee in the hose, about 10" from the intake manifold, then you have the pump. Right about where I put a Tee for my catch can system, here(right side of pic, white Tee).
Old Jul 28, 2017 | 07:47 PM
OR, if there is a fuse and relay installed for it
Old Jul 28, 2017 | 08:07 PM
That too. Although I just read a thread here a couple days ago, where the dealer installed the pump, but never put the relay and fuse in, because they couldn't get the programming to make it all work...
Of course, this was in a manual trans car
So yeah, the fuse and relay would be there if it was installed in this here case. Relay #24 and fuse #8, not sure if you already posted that.
Old Jul 29, 2017 | 09:04 AM
Geeze's Avatar
Thanks to everyone,I will look later.Very interesting pictures,it shows me everything.I checked the car fax and it looks like it was never installed.The car had 2 owners before me.I bought it with 47750 miles on it . Geeze
Old Jul 29, 2017 | 09:09 AM
  #26
Attachment 45281
Attachment 45282
Well looks like the sites images are still wonky. Don's post just now showed up for me.
Old Aug 12, 2017 | 07:43 AM
  #27
Geeze's Avatar
I would like to let every body know that my car had no x pump for the brake .It was not covered by GM or extended warranty,like you guys said. Thanks for your input. Geeze
Old Aug 12, 2017 | 09:30 AM
  #28
Your free solution is to sit in the car for a couple minutes between starting the car and putting your foot on the brake pedal. That will give the vacuum time to build up.
Old Aug 12, 2017 | 11:51 AM
  #29
Geeze's Avatar
The service manager who was a complete A hole .He told me that there was nothing wrong with the brake system, but if I want to install the vacuum pump it would be 1,600 dollars.I declined. I intend to stay the way it is. Thanks geeze
Old Aug 12, 2017 | 12:19 PM
  #30
It is amazing that the mere mention of the word "TSB" can turn service writers into A holes. I have experienced it a few times.
