Power steering recall?
Old Mar 13, 2022 | 06:46 PM
Crystal Jenkins's Avatar
so I just ran the vin on my 2009 HHR and there is an open recall on it for the power steering.
Old Mar 13, 2022 | 07:23 PM
to the forums!
I moved your post to this new thread, it's unrelated to the thread that you posted it in.
Old Mar 13, 2022 | 07:34 PM
to the forums!
I apologize, the only reason I posted that response was because he had stated he had no recalls that he knew of
Old Mar 13, 2022 | 07:56 PM
No problem, so you don't need assistance?
Old Mar 14, 2022 | 01:58 PM
PulpFriction's Avatar
Some HHRs had a power steering recall, others, an extended warranty.
I didn’t think 2009 was subject to the recall, only to the extended warranty, but that’s from memory.
You can check you VIN for open recalls on the NHTSA site, or with any GM dealer. If it’s open, you should have it done.
If not, don’t worry about it unless you have power steering trouble. Then you need to pester a GM dealer (or two.) They may not be aware of the extended warranty. Typically $0 repairs are reported but so is the need for persistence.
Old Mar 14, 2022 | 02:29 PM
You got it backwards. 2009-2010 are are recalled, all others are covered by the extended warranty (which is a sort of recall). This recall includes HHRs that had the PS motor replaced before 2010 (because they were being replaced with the original bad part).
It is a safety issue because loosing the power assist while driving can be really bad. Imagine it suddenly quits in the middle of a tight corner that you were using a finger to control.
FLORIDA
Jan 26, 2017 08:17 AM
beltrunner
Feb 15, 2015 11:14 PM
garyw
Apr 4, 2014 11:33 PM
Annabelle's owner
Mar 11, 2014 08:26 PM
chevygirl08
Nov 18, 2013 11:39 AM
