Power window motor
Power window motor
The passenger window started to have problems rolling up. You had to play with the switch on either the passenger side or the switch on the drivers side. Currently unplugged to prevent window from going down and unable to get it back up. Are the motors prone to failure? Where is a good place to get a window motor from?
Clean the switch contacts, no need to remove the door panel
https://www.chevyhhr.net/forums/how-...ontacts-62119/
Both switches go bad in the same way, at the same time? Unlikely, but not impossible.
Maybe something in the logic part of the passenger door switch.
yes, you would have to keep pushing the switch. Passenger side eventually got to where it wouldn’t work at all. Drivers side you had to play with it and sometimes it would work.
