Power windows
does anyone have trouble with trying to get the back windows to go down from the drivers switches . can use the back passenger both sides and then close them with drives switch.
Sounds like you have a failing power window switch assembly, the part number for your 2009 is 25789692, GM's list price is $70.72. You can do a Google search on the part number and find them much cheaper.
Of course you may just have a loose or corroded connection on the switch itself, here's an "exploded" diagram of the door. http://parts.nalleygmc.com/images/pa...121T14-029.JPG Our "Search" function will turn up a few threads on removing the inner door panel, it's not too difficult. |
wow thanks im a newby here on the site just learning . great info
I moved this to problems and repair
Originally Posted by Lucky
(Post 751491)
Knew there was something I forgot to do. |
| All times are GMT -5. The time now is 05:15 AM. |
