Re-setting Tire Sensors
Is there a simple way to re-set tire sensors or do I have to have the dealer do it thanks John B.:cool:
its in the manual somewhere-its easy but u need a compressor on hand, or be at a service station. As I recall you have to let air out as part of the process.
Hold the lock and unlock buttons down with the ignition turned on.
The horn will beep 3 timed and then you can either put in air or let it out starting at the left front and moving clock wise around the vehicle. Once you let enough air out or in the turn light at that corner will flash and the horn will sound. Once you complete the last tire the horn will beep 3 times. |
Thanks!:cool:
