Rear Axle Brake Lines
Old Jul 18, 2024 | 09:53 AM
greg8453's Avatar
You best replace all the lines at the rear.
Old Jul 18, 2024 | 10:36 AM
Link is in my sig
Old Jul 18, 2024 | 12:11 PM
Eman6213's Avatar
Originally Posted by donbrew
Link is in my sig
Ya, I've already looked all thru the book... The only thing it talks about for jacking up the vehicle are the pinch welds along the sides...
Old Jul 18, 2024 | 01:23 PM
You missed the part about the arrows pointing to the points.
Old Jul 18, 2024 | 01:39 PM
Eman6213's Avatar
Originally Posted by Eman6213
Also, where is a good jack point I can use in the rear to get the car high enough to remove the back tire to get at the line to remove it? The pinch weld spot on the side near the tire is rusted and too brittle to put the jack there...
You missed the part where I said that spot is rusted and too brittle to put the jack there...
Old Jul 18, 2024 | 03:27 PM
Where is that part?
If that spot is too deteriorated to support the car it is too deteriorated to drive. In some states that would fail safety inspection.
Old Jul 18, 2024 | 03:31 PM
Use the plate in front of the rear axle bushing a strong lift point
Old Jul 19, 2024 | 08:28 AM
Eman6213's Avatar
Thumbs up
Where is that part?
Ok... Guess I'll just get it towed to the junkyard instead...
Old Jul 24, 2024 | 05:46 PM
Eman6213's Avatar
Tips for removing broken brake bleeder screw
Bleeder screw broke off trying to bleed the rear... Any tips/suggestions for how to remove it?
Old Jul 24, 2024 | 05:49 PM
New wheel cylinder and line would be the best way.
