Remote Start Battery
Has anyone had to replace the battery in their remote start yet? If so where do you get the batteries
Thanks Glenn |
Do you mean the key fob battery? Look on the back of the key fob, the battery is a CR2032. You can buy them pretty much anywhere that sells watch batteries. Try your local drug store, convience store, grocery store, or places like Walmart and Target.
:confused: Is just changing the battery enough? Does it need to be reprogramed?
take apart fob
take out battery put in new battery push fob together point at car push button needed LOL,,, had to say that i use a pearing knife which has a very thin blade to get it apart. slide the edge in and pry carefully with the sharp edge of the blade pry the back off so where the back is up and it just pops off. slide battery out and change it with the back up, lay in the cradle where it came from, ease back down and then push till sealed |
Thanks guts I have passed on this info. This forum is excellent. Full of useful info and speedy responses
Thanks to all. I have passed on the info to another proud owner of an 2LT. I have also become a member. There is so much excellent info on this site and the response time is super.
Thanks again |
