Remote Start works then kills engine
Y'all have saved me a ton of time and headache in the past with just about every issues that's come up with my HHR.
So here's the latest issues(sorry if its somewhere I'm at work and on my Iphone) I can start the car with the remote start. The engine will fire up and run for about 10 sec then turn off. Once its off it won't start unless Via the key. I just had a new 140 amp alt and battery installed about 2 weeks ago. any thoughts?? 06 HRR LT with 126050 Mi |
I would stop by your local parts store and get the codes read. It may give you a place to start.
If there is a code in the system the remote start will be disabled. Although with a code in the system the remote start shouldn't work at all but sometime weird things happen. |
My wild guess is that the tech jiggled a wire while replacing the alternator.
Does the lock & key icon light up on the dash after it stops? Are all of the doors closed and locked? Any other seemingly unrelated quirks going on? The remote start involves a couple of computers, you never know what they think is important. |
Is the hood closed switch adjusted correctly?
sorry for the delay will check the above and post back
a |
Yes the lock n Key icon come on but then shortly turn themselves off again. All doors are locked and it doesn't look like there's anything funky with the hood or its latch...
Thoughts before I drag it in for the codes or back to the shop that did the work? Edit: I did notice that my dash and headlights are flickering again depending on the power load, nothing like they were before the alt replacement but still there. wondering if I got a bad alt |
Originally Posted by maveric191
(Post 762018)
Ok back from the shop that did the work. We've checked the electrical system top to bottom with nothing out of place loose or missing. They did find a TSB(06-06-03-003) that describes the issue to a T. Guess it's off the to dealer for a reflash again, Had them reflash it a couple months ago to see if that dang loud crack would go away in the audio on some starts. >:-(
Well that's new seemingly unrelated info.
