Removing drivers power window control panel from door?
I searched and could not find an answer to this. I took the two screws out of the arm rest but the control panel won't come out. I did see there is a tab holding it in towards the drivers elbow side. Do I have to remove the door panel or can I unlock the tab(s) in some way without doing so. Thanks!
You do have to mess with the tabs. There is a thread somewhere about it. If I get a chance I'll try the search for it.
| All times are GMT -5. The time now is 09:36 AM. |
