Replacing Shift Assembly 09 HHR
Old Sep 19, 2013 | 07:41 AM
alexpol's Avatar
Hi All,
I bought a new shift assembly because I need to fix the key stuck in the ignition problem. The dealer has already fixed for free the ignition itself just in case that was the problem (it wasn't).
Can anyone tell me HOW to remove the old assembly?
Old Sep 19, 2013 | 10:48 AM
Check your PM, it's there now.
Old Sep 19, 2013 | 10:49 AM
alexpol's Avatar
thank you
Old Sep 19, 2013 | 10:59 AM
It's for 2006, but it helped me with my 2011.
Old Sep 19, 2013 | 12:30 PM
alexpol's Avatar
yep. Just finished. Took me and my son 1 hour.
Here are the pain points to avoid.
1. Cut the old wiring off. It helps you remove the old wiring harness later.
2. Use a wrench with teeth to gently pull the yellow plastic shift arm off the assembly.
3. Pull the housing seated into the front of the housing straight up.
When installing:
1. Put wiring harness in first.
2. Slide the housing from front to back through the seated hole in the new housing. Those strange wings give you a clue as to the direction.
3. Fit the new shift arm on.
Finally,
Do what you can to raise the old floor bolts and tighten the nuts. We only could get 3 back on but it is still firm to the touch and has no play in it.
Old Sep 19, 2013 | 01:30 PM
I was just getting ready to tell you to use the search box, there is a thread about the replacement job, including tricks for the nuts.
Tkicks
13
May 29, 2015 12:19 AM
jmm121783
Jul 18, 2014 10:17 PM
pbatmen
May 18, 2014 08:53 PM
charhhr06
Sep 12, 2013 03:58 PM
