Research Topic: Airbox replacement mounting grommets
Note: This is a research topic. Please post only information for the grommets(insulators) requested in this post. Any off topic posts will be deleted. Any help is appreciated, thank you.
Can anyone give me the correct part # for the 2 large mounting grommets at the back side of the airbox? Dealer first tried to give me 3 of the same ones(12563914), which was the smaller one up front. Next they game me 2 of 19177871 but they are also wrong. |
Or records show the following - Air Filter Box mounting Grommet - GM calls it an "Insulator"
- P/N - 12563914 |
Mine have always been the same size, 2008 LT and 2011 LT.
Originally Posted by whopper
(Post 805854)
- P/N - 12563914 |
What year HHR and size engine do you have ?
Maybe the earlier models were different? |
Here is another from, A better choice I think
for LNF: INSULATOR. Air Cleaner. AIR INTAKE SYSTEM for 2008 Chevrolet HHR. #25920906 for 2.2/2.4: http://www.wholesalegmpartsonline.co.../12563914.html |
3 Attachment(s)
Originally Posted by Oldblue
(Post 805868)
It's a 2008 2.2 1LT per his profile
12563914 Shows for a Traverse 12591715 Shows for a Buick , Caddy, Chevy Our list of part numbers shows 12563914 is the correct number per https://www.chevyhhr.net/forums/comm...-part-i-48833/ |
2 Attachment(s)
The one I need on the left, and 12563914 on the right. The parts diagrams are wrong! 2 of these bigger ones go in the back. 1 of 12563914 goes in the front.
What about the part number molded into the part?
FWIW, I just put a piece of carpet padding on the front stud. Your housing is different from either of mine. Mine had 2 on the back and a leg in the front with the grommet that got destroyed the first time I took it off. Do the smaller ones fall out of the holes even after the stud is in them? As I recall that expands them considerably. |
| All times are GMT -5. The time now is 05:52 AM. |
