Research Topic: Airbox replacement mounting grommets
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
OK donbrew. Good idea when you can find them.
You could be right, but the general says all of the other rubber/nitrile parts are oem GM quality. So you should buy their parts. They will last longer.
I went to OEMCATS.com and they say 19178771 is interchangeable with or replaced by 12563914 and or 15809014. It/they is/are a 1.00 inch diameter grommet.
I've received a lot of help from this community so with this I try to pay some of it back. All credit goes to Eli at Keyes Chevy in Van Nuys, CA.
Rear insulator part#: 19177871
I hope this helps some people! The insulator on the right is from my car (2007 HHR 2.4 manual).
The air box in my 2.2 2007 had the identical sized grommets at the rear as my 2011 does. So possibly Steddy Teddy had an incorrect part in the bag. It happens
I have a 2009 LT2 2.4L. I just finished replacing the intake solenoid and thought I may have to change out the insulators on the airbox. I think I read this thread 3 times to try to figure out what parts to order to have on hand.
For the back I got GM # 19177871. They matched exactly the ones on the car and had the same number molded in the rubber.
The front insulator had disintegrated so there was nothing to compare. I had ordered GM # 12563914 and it worked fine.
