rich to lean and lean to rich
Old Apr 19, 2016 | 08:44 AM
BDR1973's Avatar
This has been a common problem with my HHR LT 2010 2.2L with about 122,240 miles on it so far. Some times it has a P0172 (rich condition),CEL goes off and comes back on as a P0171 (lean condition). When car was at dealership for about a month with my gauge probelms (car was running lean for them). They did a smoke test for a vacuum leak and found none. They changed the purge valve and no charge ( CEL pointed them in that direction). Car runs fine and I still haven't checked the fuel pressure yet. We even used some brake cleaner to test for vacuum leak and found none. Any suggestions as to check or test next.
Old Apr 19, 2016 | 09:37 AM
skyline26's Avatar
hows the maf sensor? clean it with a proper maf cleaner or try replacing it
Old Apr 19, 2016 | 10:41 AM
BDR1973's Avatar
i've cleaned it a couple of times now. i already changed the O2 sensor (upstream) and have the downstream O2 sensor on its way.
Old Apr 19, 2016 | 11:49 AM
Probably not going to be the O2 sensor.
Try the Search function for P0171. Numerous threads in regards to this code.
Checking the fuel pump would be my suggestion.
Old Apr 19, 2016 | 12:42 PM
search youtube for "fuel trim". There are several good vids about that so you can understand what it actually means.
I can try; basically the #1 O2 sensor tells the computer if the engine is running rich or lean. The computer then tries to adjust the A/F ratio to the perfect stoichiometry. Sometimes it compensates one way and the broken part forces the sensor the other way too far.
The #2 O2 sensors monitors the health of the catalyst using data from the #1 sensor, so that is not a suspect.
I would take a flying guess at a bad injector.
Having them cleaned and tested costs about the same as new ones. If you replace them be sure they are the identical part numbers.
They replaced the purge valve under the hood? Or the one by the gas tank?
Old Apr 19, 2016 | 12:49 PM
BDR1973's Avatar
They replaced the one under the hood.
Old Apr 19, 2016 | 01:16 PM
DrLoch's Avatar
I 2nd that.
Old Apr 19, 2016 | 01:31 PM
Per P0172
http://www.obd-codes.com/p0172
I'm more inclined to the leak aspect, as in flex joint in the exhaust leak!
Old Apr 19, 2016 | 02:31 PM
BDR1973's Avatar
OLDBLUE, what kind of sound would I hear if leak in exhaust (flex part).
Old Apr 19, 2016 | 02:35 PM
Depends , I heard a muffled rumbling , sound
