Right rear turn signal bulb keeps blowing
Pretty much what it says, our 2011 LT keeps blowing bulbs. Back in early march I heard the fast clicking, so I replaced the bulb (a little dark) and all was good. A few days later, the left rear went out. It's been fine since. Two weeks later and the right rear did the fast clicking again. This time the bulb was all whited out like a phosphorous explosion. Replaced it. Almost month later and last Friday it is fast clicking again. This time, the bulb had shattered! I replaced it again.
Any ideas what might be causing these bulbs to blow? A short or something?
Not saying this is the problem, but are you sure you're using the correct bulb and not an "extra bright" one?
Also, I drilled holes in the housings for extra cooling.
Don't by the same brand bulb that keeps blowing. There can be whole runs of bad bulbs.
I couldn't find another brand at either store, or I probably would have bought it.
