RUNNING BOARD SWAP Between SS and LT
I am likely the newest member so hi guys and gals! I have had a loaded 2006 HHR LT with running boards. I now also have a nice 2008 HHR SS and want to swap the running boards. I searched and only found the entry where the lady installed herself. SOunds pretty easy to get them off and back on but that was not very specific. Anyone know how to get a set of directions I can refer to? Call Chevvy Dealer?
Also know if the boards will swap between the two cars? Thanks much! Tim in Phoenix AZ And in case you are wondering it was 72 here today.:smile: |
Welcome to the site. :thumb:
Directions ? It's just a simple bolt/unbolt process. Not like it's something complicated where you would need a set of directions. As far as swapping between the 2 cars. Not sure. Someone else will have to answer that. |
