Service ESC Traction control ESC off
Old Jul 14, 2020 | 02:05 PM
Cat Man HHR's Avatar
Why is this #10 post the same as #1 ?
Old Jul 14, 2020 | 02:07 PM
captneuman's Avatar
Because someone mentioned that 20 questions gets frustrating and that I should just start from the beginning up front! I thought I was clear!
thanks
Old Jul 14, 2020 | 02:10 PM
thanks
No that was not.
Let's try to go thru this.
"Okay I need some help
the serpentine belt broke the other day, the battery light came on, I drove 4 miles to my house, used a different car and got new serpentine belt, installed it and now the
Service Traction Control warning
Service ESC warning
ESC OFF warning and icon
have come on!
had my mechanic try to clear the codes
unsuccessfully
any ideas as to what my issue is!
absolutely no change in the way car drives"
Got the help thing.
If the belt broke, on a long shot, it caught the wires to the front hub on the right side to cause the ESC to come on.
Have your "mechanic" look into this possible problem.
Ask your "mechanic" why he/she can't erase the codes ?
If codes are still there and the check engine light is on it's a hard fault.
If not, you can still (with the correct code reader) see what they are.
Old Jul 14, 2020 | 02:12 PM
captneuman's Avatar
See number 8 post
Old Jul 14, 2020 | 02:14 PM
Copy and paste does not add any information
Like the new battery.
What happened just prior? Any semi recent history may help.
Old Jul 14, 2020 | 02:17 PM
Get the codes read and post the numbers here...
Old Jul 14, 2020 | 02:21 PM
CEL= Check Engine Light. This comes up on the dash readout-- CHECK ENGINE-- when a trouble "code or codes" is set.
quote: "Service Traction Control warning
Service ESC warning
ESC OFF warning and icon have come on ! "
The above are not "codes" but Warnings. You don't clear Warnings.
Old Jul 14, 2020 | 02:22 PM
captneuman's Avatar
All that happened was the serpentine belt broke battery lite came on
I replaced the belt and then I had the DIC say
Service ESC
ESC OFF
mans the traction icon lit
thats it in a nut shell
I replaced the battery weeks ago
Old Jul 14, 2020 | 02:23 PM
captneuman's Avatar
The engine lite is on! My mechanic said it’s for the fuel vapor solenoid something or other
Old Jul 14, 2020 | 02:27 PM
captneuman's Avatar
Can you please tell me where I might locate those wires? I’m feeling that may very well be the problem! Thanks
