Small fixed vent window behind rear door window is broken. Bought a replacement. give
I am hearing different things ...some say to replace the small fixed vent window is easy and does not require removing the larger door window glass ...others say it's a bigger job requiring taking out the larger window.....would super appreciate your help and I am not sure why they call it a vent window....it's fixed and doesn't open
That leads to: https://charm.li/Chevrolet/2009/HHR%...20Replacement/
I see the diagram and instructions but I don't understand it actually ....do I just remove those two screws and somehow I can get the new small vent window in without removing the larger window? ..I hope someone can clarify the procedure for me
to the forums!
