Chevy HHR Network
-   -   Small fixed vent window behind rear door window is broken. Bought a replacement. give (https://www.chevyhhr.net/forums/problems-service-repairs-42/small-fixed-vent-window-behind-rear-door-window-broken-bought-replacement-give-67922/)
Ericwest11 Mar 25, 2026 10:41 AM
I am hearing different things ...some say to replace the small fixed vent window is easy and does not require removing the larger door window glass ...others say it's a bigger job requiring taking out the larger window.....would super appreciate your help and I am not sure why they call it a vent window....it's fixed and doesn't open
RJ_RS_SS_350 Mar 25, 2026 11:56 AM
:welcomewagon: to the forums!
https://charm.li/Chevrolet/2009/HHR%...d%20Diagnosis/
donbrew Mar 25, 2026 12:29 PM
That leads to: https://charm.li/Chevrolet/2009/HHR%...20Replacement/
Ericwest11 Mar 25, 2026 10:41 PM
I see the diagram and instructions but I don't understand it actually ....do I just remove those two screws and somehow I can get the new small vent window in without removing the larger window? ..I hope someone can clarify the procedure for me
RJ_RS_SS_350 Mar 26, 2026 12:09 AM
You need to look at the "refer to"s.
donbrew Mar 26, 2026 08:01 AM
The smaller window is part of the whole window frame/trim. the trim is held in with the 2 screws and the pinch weld flanges.
https://cimg5.ibsrv.net/gimg/www.che...736cfde980.png
