Soft Brake Pedal
Old Mar 10, 2024 | 10:27 AM
  #31
Fire_Wessle's Avatar
Originally Posted by donbrew
Mirror images. the lever and short part mount on the rear shoe.
Got it, i'll take the drums off again on Tuesday to fix it amd post an update.
Old Mar 29, 2024 | 02:59 PM
  #32
So the drums were definitely part of the problem but I just had the booster replaced amd that seems to have fixed the travel issue and the lack of stopping power.
However I believe the booster I received from Rock Auto is defective. Regardless if the car is on or off, the brake pedal now clicks, drops an inch or two with zero resistance, then continues applying pressure to slow to a stop. I already got a refund on the part and ordered another that should arrive on Monday. I know there is no way to fix this booster but am i risking total brake failure if I keep driving on it?
Old Mar 29, 2024 | 03:51 PM
  #33
With brakes, don’t drive it until you fix the problem.
Old Mar 29, 2024 | 04:38 PM
  #34
I figured as much, just wanted to be extra sure.
Thank you!
oatesnotes
13
Jan 26, 2021 12:03 PM
TruckerKevin
Jan 15, 2021 09:09 AM
Briguy64
Jun 2, 2018 04:32 PM
dande54
Apr 12, 2016 07:02 PM
Clob285
14
Apr 11, 2016 10:10 AM
