Speedometer fluctuates
Old Jul 21, 2025 | 10:57 AM
Burntable's Avatar
2010 HHR speedometer fluctuates and transmission changes hard, I've replaced the transmission speed sensor and all four hubs with new sensors,any idea what it could be
Old Jul 21, 2025 | 11:42 AM
I’m thinking those 4 bolts in the under hood fuse box need to be tightened up! Then press all the fuses and relays firmly into position, start there!
Those 7 mm bolts!
Those 7 mm bolts!
Old Jul 21, 2025 | 01:20 PM
Any CheckEngineLight?
Why did you replace the hubs and speed sensor
Any work done before this started?
Old Jul 21, 2025 | 05:14 PM
Burntable's Avatar
Speedometer fluctuates and transmission changes hard
No codes
Old Jul 21, 2025 | 06:52 PM
Tighten bolts??
Old Jul 21, 2025 | 07:52 PM
Burntable's Avatar
No, do you think I should
Old Jul 21, 2025 | 07:57 PM
Burntable's Avatar
Bolts
Originally Posted by Oldblue
Tighten bolts??
I checked the bolts on the fuse box all are tight
Old Jul 22, 2025 | 02:59 AM
Burntable's Avatar
Codes
Check engine light is not on
Old Jul 22, 2025 | 07:14 AM
Burntable's Avatar
I had to start somewhere
Old Jul 22, 2025 | 02:13 PM
greg8453's Avatar
Originally Posted by Burntable
No codes
Did you scan the TCM?
