Stalling motor. Larger than we know ?
Old Jun 29, 2007 | 09:18 PM
Alzonie's Avatar
No such problem with ours. Approaching 11,000 Mi. Almost 2 years old.
Old Jun 29, 2007 | 09:26 PM
Navyflyer11's Avatar
I haven't had any problems like that. I have over 45,000. KNOCK on WOOD.
Old Jun 29, 2007 | 10:55 PM
Pretzel's Avatar
Hello,
I talked to my coworker today and asked if they had fixed the problem. He said it seems to be ok now. They told him they found a wire going to one of the fuel injectors chafed threw and grounding out?
Would 1 injector kill the whole engine without some spuddering ?
Craig~
Old Jun 30, 2007 | 07:18 AM
SandyBeach's Avatar
I can't answer that but since you both live in the same area, did you consider bad gas? I know you guys have had a ton of rain lately.
Last summer I had the check engine light come on and the code was a bad oxygen sensor. Fortunately, mine never stalled on me. Then I read in the owner's manual about how you should use gas from the same station every time. Apparently gas can vary enough to trigger the check engine light.
I'd find a station with reliable gas and stick to that one or others selling the same brand of gas.
By the way, my problem occurred shortly after buying the HHR also. However, I haven't seen the problem since that first time.
Old Jun 30, 2007 | 11:37 AM
nfboy's Avatar
Where in the manual does it say that? I just went through the whole section on fuel and there is not statement like that that I could find.
graffixx
12
Aug 14, 2015 11:15 AM
dadman503
Jul 15, 2013 04:03 PM
max69power
Oct 7, 2012 09:57 PM
pollock
Sep 25, 2012 07:07 PM
Alzonie
Aug 26, 2009 03:30 PM
