Steering shaft, 2009 LT 2.2 litre
Old Oct 14, 2018 | 01:57 PM
davidfr's Avatar
Steering shaft
Originally Posted by Oldblue
I just made sure nobody touched the car whilst I was working on it , and made certain I did not move things very far, and moved it gently back when it did move.
when i install my steering shaft, in securing the steering wheel straight would tying it down to a front post under the seat real tight keep it from moving? Or what would be the best way to secure the wheel?.
Old Oct 14, 2018 | 02:17 PM
That might get in the way when you crawl under there, my wheel stayed in position without a tether, You could go down over to the passengers seat rail.
Old Oct 14, 2018 | 02:31 PM
davidfr's Avatar
thanks. I just want to be extremely careful when i do this and not create further problems...should i disconnect the battery? Reason being the airbag somehow being tripped.
Old Oct 14, 2018 | 06:32 PM
Yes disconnect the battery, please.
Old Oct 15, 2018 | 08:23 AM
davidfr's Avatar
Steering shaft
[QUOTE=Oldblue;853918]
Getting ready to replace steering shaft today. Kinda puzzled. When it first started making noise it was always in the afternoons, never in the mornings. Noise is at a low minimum. Rarely hear it but a few times daily, always when turning at low speed. Wheel always goes back to center, steering is not hard. Noise started more after i had a angle sensor installed a few weeks ago. If im right the angle sensor goes at the end of the colum, in front of the yoke under the dash. This part has more than likely been on car since 2009. Im thinking shaft is really the problem. But trying to be sure.
Old Oct 16, 2018 | 08:56 AM
  #26
aradmahogany's Avatar
Originally Posted by Ohiocruiser
The hardest part for me was to insert back that rubber boot.
That boot is a MOTHER****ER really. That literally is the hardest part. A FAIR WARNING that this will fix the rattle sound for some, but for others, including myself, the rattle is form the steering column itself, requiring removal of the wheel, air bag, etc.
Old Oct 25, 2018 | 06:22 PM
  #27
davidfr's Avatar
Funny story,
Last week i was in process of changing my steering shaft. After tying the steering wheel, i barely nudged it and the horn blasted till i disconnected the battery. Being unnerved i gave up on the steering shaft. My wife had earlier said that the knocking problem may be the sway bar links, so i installed 2 new links and have had no further problem with knocking or thump thump when turning. Guess the problem is solved.
Old Oct 26, 2018 | 01:36 PM
  #28
I would still change that intermediate shaft.
Old Oct 26, 2018 | 01:55 PM
  #29
davidfr's Avatar
oh believe me i will this weekend. It was funny about the horn. I know i didnt do any damage. This time ill unhook battery first.
Old Nov 3, 2018 | 06:28 PM
  #30
davidfr's Avatar
Changing my intermediate steering shaft for sure tomorrow. Which yoke is recommended to be removed first, the one under car, or under the dash. Any tips on changing shaft would help. Never changed one before.
