Steering shaft, 2009 LT 2.2 litre
Old Nov 3, 2018 | 06:58 PM
  #31
davidfr - lets keep this in a single thread rather than starting a new one each time you have a question. 3 threads merged into this one.
Old Nov 3, 2018 | 07:00 PM
  #32
The underhood, Drive it up with gentle taps from the hammer and a drift to reach it from underneath
Old Nov 3, 2018 | 07:16 PM
  #33
davidfr's Avatar
Steering shaft
Will do, and thank you. Ive still got all your previous information.
Old Nov 4, 2018 | 04:08 PM
  #34
davidfr's Avatar
Steering shaft
Installed steering shaft today, following donbrew's instruction. Disconnected battery, tied wheel straight, the tough part was actually getting bottom yoke to slide over attaching shaft so i lightly tapped the slot with a pry tool and hammer. Yoke slid on perfectly. Lining up the top yoke was easy. Lined up nicely. I was very careful and it took me about an hour to finish. The end result was well worth the time to install it. Oh, my old shaft, upon inspection was frozen. When it did give , it sounded like air being pushed out. Kept locking back up at full extension. What is the best way to re install the boot. That another question? And can it be done with shaft installed?
Old Nov 4, 2018 | 05:33 PM
  #35
davidfr's Avatar
Originally Posted by Ohiocruiser
The hardest part for me was to insert back that rubber boot.
How did u end up getting rubber boot back in place?
Old Nov 4, 2018 | 05:56 PM
  #36
I used an 18 inch 3/8’s drive extension and gently worked from the bottom to the top on both sides
Old Nov 4, 2018 | 06:06 PM
  #37
davidfr's Avatar
Great, thanks for the info. Ill do that tomorrow morning. Never thought of that. Thanks again.
Old Nov 4, 2018 | 06:17 PM
  #38
I wanted to avoid using something like a screwdriver or the like, didn’t want to poke a hole in the boot.
Old Nov 4, 2018 | 06:27 PM
  #39
davidfr's Avatar
Yep. That boot seemed to me at the time the hardest of the whole job. Im going to keep the boot from my old steering shaft so ill have an extra.
anthony303
Oct 25, 2018 10:35 PM
intruderdct
Drivetrain (Excluding Engine)
Apr 3, 2017 07:54 PM
vogtrj
Jan 18, 2017 09:15 AM
MCHHR
Oct 4, 2016 03:00 PM
snj
Aug 28, 2012 12:07 AM
