Chevy HHR Network
-   -   Strange cruise control behavior (https://www.chevyhhr.net/forums/problems-service-repairs-42/strange-cruise-control-behavior-24584/)
WEB Jul 15, 2009 03:39 PM
I've spent some time searching the forums and didn't find this exact issue discussed; I hope I'm not repeating something that has already been discussed.
I've discovered an idiosyncrasy in the cruise control system of my 2008 SS which seems to be unknown to the service techs at my dealership, and I'm wondering if it is unique to my car.
A few months after I bought the car there was an occasion when I tried to engage the cruise control shortly after leaving a rest stop on an Interstate highway, and it failed to engage. Nothing I tried would make it engage. Some time later during the same trip when I tried to engage it, it worked normally. I figured I had some sort of intermittent electrical problem. The situation didn't recur for a few weeks, but again it was a case of trying to engage the CC shortly after I had started the car. For reasons I can't explain I thought maybe after starting the engine the brake pedal had to be depressed at least once before the CC would engage. I tested my theory and it works every time. If I don't apply the brake sometime before trying to engage the CC it will not engage. After I tap the brake it works normally.
Has anyone else discovered this?
Bill in Cincinnati
txbass06 Jul 15, 2009 03:57 PM
Do you leave your cruise turned on all the time? My friends H3 does the same thing if he leaves the cruise on. It's never happened if he only turns the cruise on when its being used.
WEB Jul 15, 2009 04:08 PM
I leave it switched on all the time.
Bill in Cincinnati
txbass06 Jul 15, 2009 04:16 PM
Next time this happens, try switching the cruise off for a second then switching it back on
WEB Jul 15, 2009 04:26 PM
That's one of the first things I tried when it happened the first time. It had no affect.
Bill in Cincinnati
87silver Jul 15, 2009 10:05 PM
Shot in the dark, but do you periodically push all the fuses, relays, ckt brkrs and BCMs into their sockets? They're under the hood as well as the passenger side interior kick plate. I do this monthly and have not had an electrical issue so far. Maybe there's something to it or maybe it's just luck, but it doesn't hurt.
CarlsSS Jul 16, 2009 03:48 PM
Bill in Cincinnati
Sounds to me like the switch that links the brake petal to the cruise disengage is sticking...
I have a manual trans, and the clutch switch was doing this to me once in a while. If I pushed the clutch in/out a few times a little more deliberate, then the cruise would start working again. It has been working fine for almost a year now. I think it just took a while for the switch to free up or wear in...
If it is under warranty yet, I would tell the dealer to replace that switch.
DMarotta Jul 17, 2009 01:04 AM
Bill in Cincinnati
YES!!! Same thing happens to me. (08 auto)
I too leave the cruise control on most of the time but that is because I use it. It happens out of the blue.
I found that if you come to a complete stop and put the car in park and shut the engine off it resets with the next start (reboot if you will). It does not reset if you go to nuetral and shut the car off while gliding then restart the car. (I'm sure that is a bad thing to do at some level but it was worth a try)
Jeff® Jul 17, 2009 07:26 AM
How do you shift in to gear without pressing the brake? :confused:
REDHHRSS Jul 17, 2009 09:01 AM
I had a problem yesterday when I had the auto light control off My cruise would not ingage till I hit the information button to remove it from the display.
Pat
