stumbling at idle....fuel issue?
Old Feb 20, 2022 | 10:12 AM
I can't test it from here. Go to the store you bought the battery from and have them test the system. Under 11 volt it is a wonder it started.
Kind of sounds like the alternator is not charging the battery, but could be a lot of other things.
Old Feb 20, 2022 | 10:47 AM
The RPD has a voltage readout. Jump the car again and check the voltage with it running. It will show if it's charging. +14 volts (if the battery isn't shorted and dead.)
Old Feb 21, 2022 | 11:51 AM
fst100's Avatar
i charged the battery overnight and got the car started. voltage on RPD was 14.2-14.4v but after 3-5 minutes it stumbled and stalled. started it again and it struggled. took the battery out and took it to advance auto where i bought it to get tested. the battery tested good so it leads me to believe it may be the alternator which sucks since the car's parked on the side street.
edit-are there any differences between the non-turbo and turbo versions for alternators or year differences? majority of the search on this forum i only seen were members with the 2.2 and 2.4
Old Feb 21, 2022 | 04:40 PM
Quote : "so it leads me to believe it may be the alternator"
Uh...why would you think that ?
The Alternator voltage output appeared fine. You recharged the battery so I doubt it just went dead after 3-5 minutes with the engine running. Did you check the battery voltage when the engine died ? Or you just took it to AA to have them test the battery. Saying the battery tested "good" doesn't mean much.
What was the voltage after you charged the battery ? What was the voltage status after they tested it ?
Old Feb 21, 2022 | 06:05 PM
fst100's Avatar
Voltage was 11.7ish when it died. When I restarted it, voltage was 12.6ish. Voltage after charging it according to the battery charger was 13.2 or 95%. AA showed 12.6v which should had enough to start the car. Cold crank and everything else showed in working order
Old Feb 21, 2022 | 06:25 PM
  #26
Ok, thanks. 12.6 volts should be enough, what were those CCA numbers?
Old Feb 21, 2022 | 07:05 PM
  #27
fst100's Avatar
Didn't get the print out but IIRC the cca was 650 or 660?
Old Feb 21, 2022 | 08:16 PM
  #28
Checking the voltage with the engine running is reading the alternator output. Checking it with the engine off is reading the battery voltage.
Old Feb 22, 2022 | 02:17 AM
  #29
fst100's Avatar
the voltage was 12.5/.6v both idling and motor off when it was stumbling.
Old Feb 22, 2022 | 06:33 AM
  #30
So I guess the 14.2-14.4v in post #23 was a typo ? Lots of confusing info here. Hard to suggest anything to check for.
