sunroof drain hole location
does anyone have a picture of the sunroof drain hole location? I have a leaky roof when I go through a high pressure car wash and the water runs into the cabin through the open/close switch area. Thanks in advance for any help.
Found this image, there appears to be a third drain line.
http://parts.nalleygmc.com/images/pa...191T12-017.JPG
I always figured there had to be a rear drain, although I don't know how you could reach it without taking the whole sunroof apart. My 2 front drains were very clogged up creating a flood in my car whenever it rained.
Sunroof drains
I checked with the dealer and there are drains at the rear corners, each side. You can see the drain lines in the spare tire area. They drain thru the rear panel below the covering around the rear hatch latch. I passed air thru the lines but nothing changed. The lines connect to the sunroof assembly at the back corners just like the front. It looks like the headliner must come down.
Any better solutions are welcome. Please, I haven't fixed mine yet!!
If your drains are disconnected at the sunroof you will also have a moist smell from the front seatbelts.
could help.
