Which Sway Bar Links? FE3
Old Sep 16, 2023 | 04:58 PM
autahciscoguy's Avatar
I tried searching and didn't find a straight forward answer. I have a 2LT with the FE3 suspension code. Should I be using the 9" or 11" sway bar links? (Or 11" and 13" depending on where you buy them. UGH)
Edit: One of the suggested posts seems more straight forward than what I found in search. I'm going to get the shorter ones unless someone tells me otherwise.
Old Sep 16, 2023 | 05:48 PM
Yes, in this case, shorter is better.
Old Sep 16, 2023 | 06:29 PM
Can't find a straight forward answer? I know that I have poste 10 inch (9.86) at least 100 times. The part number usually ends in "252", the ones that end in "10" are 12 inch.
Most parts books are wrong or inaccurate.
Old Sep 16, 2023 | 06:58 PM
Yeah. What came up when I searched wasn't helpful at all. When I posted the suggested posts were.
Old Sep 17, 2023 | 06:51 AM
Moog K750012 are popular
Old Sep 18, 2023 | 09:25 AM
PulpFriction's Avatar
I would measure what I have and get those.
Also, I once replace just one at 30k miles, the other was fine when I sold the car w over 100k.
Old Sep 18, 2023 | 10:08 AM
But what if a previous owner changed them with the wrong length links?
Old Sep 18, 2023 | 10:26 AM
Yes of course. To be thorough, one could give the Vin to any GM parts department, and they should be able to give you the correct GM part number. They might even have one in stock you can measure. But if there's no problem with the current length, why not? The most important thing is that they both be the exact same length.
i suspect GM was not terribly consistent, and used whatever they had that would work.
Old Sep 18, 2023 | 11:40 AM
Or just look at post #5, not complicated, tried and true fitment.
Old Sep 18, 2023 | 03:48 PM
GM parts books have the same errors that the others have. They will try to sell you the wrong LCAs for your SS and the wrong t-stat just like the guy at Advance.
The CORRECT links are 9.86 inches, commonly called 10 inch in the US. Doesn't matter what is i=on the car. The sway bar is a different story they seem to be whatever was in the box in the corner that day.
The reason is that 12 inch links exert more lateral force on the sway bar causing the stops to move out of place and then the sway bar can move laterally then the links make contact with the LCA. It is a lever thing, 12 inches multiplies the force exponentially more than 10 inch.
Zaydoc
11
Apr 8, 2021 11:46 AM
pbatmen
10
Oct 19, 2015 03:41 PM
Meltingside
Aug 3, 2015 07:12 AM
esmarkey
10
Mar 25, 2015 12:35 PM
TiggersHHR
Feb 19, 2011 12:50 PM
