sway bar links vs. radio........
Ok, this should get your attention!
I took my 06 to the Ford Dealership where I bought it ONLY because they were offering a free "after winter suspension check", so I thought I'd take them up on it.
Not to my surprise, they replaced the sway bar links which was no biggie.
But when I got in, after starting it I noticed my clock was 3 hours behind.
AND after turning on the radio, it was stuck on the lowest FM station (88.1) and would not respond to the "up/down" tuning and all my presets were gone!
I went back into the service department, and was not only told the mechanic was gone for the weekend, and was suggested to disconnect the positive terminal from the battery for 1/2 and hour. If this did not work, I was supposed to call them back on Monday.
I'll try the battery "rest period" tomorrow, but wanted to get this posting up to see if this has happened to anyone else.
well, as per donbrew's suggestion, I tried the key fob a few times, but i still can't access the clock to reset it, or use my memory presets.
kinda pisses me off that this is even an issue.
"radio/electronics vs. swaybar link replacement"...........COME ON!
