Temp guage not working
started my 2007, 2.2l engine and after a few minutes noticed temp guage did not move, then looked to DIC and nothing for temp registered, car runs OK, not overheating, any clues, haven't started trouble shooting yet as i was just getting home from a trip. any suggestions to start looking?
many thanks for input Beachbum |
Sounds like a bad thermostat. There have been many, many threads here about this problem and these same symptoms.
Do a search here and you should be able to see numerous posts and solutions and possible warranty coverage. |
(Post 676929)
As Fireman says....Thermostat.
You are making the assumption the thermostat went bad and CLOSED. It went bad and OPENED. As fireman says you have all the symptoms of this problem. When this occurs everyone wants it to be the easiest repair possible....the sender. But 99% of the time it's the thermostat. But you can test it to some point. Start up your car and let it run to a point that it SHOULD be normal operating temperature. Raise the hood and check the radiator hoses. They should be cool or at least lightly warm.....thermostat stuck or, in some instances broken, in the open stage. Again, as he suggested, you will find MAY different threads on this topic. All of them will point to your symptoms. Do a search, it is interesting reading. Oh, and to answer you question about no temperature indicated.......and I'll be a little symplistic......that is the way the vehicle is programmed and built. You will not have other functions also.....but it isn't worth mentioning those right now. |
Originally Posted by Snoopy
(Post 676963)
I can't see why the thermostat would be where you start....
If the thermostat is stuck inclosed position, then after a few minutes of driving, you would boil over..... If it was stuck open, then it would take forever to warm up, and in this cold weather, the heater would not feel as hot as usual. Check for those symptoms..... However, no data change at the DIC and no movement on the gauge says electrical issue to me..... Check your wiring to the sending unit. If the wiring is fine, I would replace it. But, as stated above......you mentioned running a few minutes......make sure the engine is warm, and the heater is blowing warm air....then check to see if you have any readings...if not....its electrical..(ie..sending unit.) |
Originally Posted by A Crazy Canuck
(Post 676986)
If the thermostat is stuck inclosed position, then after a few minutes of driving, you would boil over..... If it was stuck open, then it would take forever to warm up, and in this cold weather, the heater would not feel as hot as usual. Check for those symptoms..... However, no data change at the DIC and no movement on the gauge says electrical issue to me..... Check your wiring to the sending unit. If the wiring is fine, I would replace it. But, as stated above......you mentioned running a few minutes......make sure the engine is warm, and the heater is blowing warm air....then check to see if you have any readings...if not....its electrical..(ie..sending unit.) Why the --- reading on the DIC? Because the car's computer senses that the coolant is not heating up fast enough. Therefore the computer sends the "no reading" to the DIC. Apparently, it's just the way GM programmed the computer to not give a reading when you have a slow warm up. The car can still warm up enough to produce some warmth from the heater. Just won't be fast enough to satisfy the computers algorithms. I still put my money on it being a bad thermostat. |
(Post 676986)
well, at least living in FL does have a benefit, I don't need the car heatermuch if at all. so I can replace one item, check and then replace4 the other if needed.
Thanks to all for your input, I just love this site. Beachbum 1 |
It's the thermostat. As Firemangeorge said, it's the way it works - and you will likely find that the A/C is inoperable at the same time as the CEL is lit (the CEL will NOT come on every time, as it is dependant on specific circumstances - but will give a P0128 when lit).
Usage of the SEARCH facility (- hint hint ;-) at the top of the page) would have quickly found this great writeup on replacing the thermostat https://www.chevyhhr.net/forums/how-tutorial-library-21/how-save-%24350-00-thermostat-replacement-2-4l-p0128-24493/ and https://www.chevyhhr.net/forums/show...ighlight=p0128 is interesting reading as well |
