Chevy HHR Network
-   -   Throttle Position Sensor (https://www.chevyhhr.net/forums/problems-service-repairs-42/throttle-position-sensor-52689/)
Agpullen Jan 7, 2015 09:56 PM
Originally Posted by donbrew (Post 768442)
Does the GM bulletin you cite specifically state your engine/model/year/size?
Oddly enough the eBay compatibility guide says no.
Thats whats I've found too. Someone has to have that part or part number. It would be better then replacing the whole throttle body.
donbrew Jan 8, 2015 08:00 AM
Everything I've ever read about says integral to throttle body, throttle bodies are less than $100 IIRC.
Oldblue Jan 8, 2015 08:09 AM
As stated in another thread the TPS is different and is not compatible with the HHR TPS!
The TPS is integral to the throttle body on an HHR
donbrew Jan 8, 2015 12:19 PM
Used TBs go for as low as $47.
donbrew Jan 8, 2015 06:08 PM
I just got around to moving this thread out of the "commonly used parts" area.
Thinking about merging the other posts by the same member on the same subject. And then I did it!
Agpullen Jan 8, 2015 09:04 PM
Well I tried to remove the TPS last night and I'm pretty sure I broke it. There is a small piece inside the plastic housing that connects to one of the gear posts and you cant open the housing to get it back on. Im just gonna have to buy a new TB. I've found them new for $150 (wouldn't trust a used one) does anyone know if I have to get a ecm reset when I install the new one?
Oldblue Jan 9, 2015 07:46 AM
I replaced one on a friends 2009 2.2 and did not require a reflash I did ensure the neg terminal at the battery was disconnected while I performed the work.
I completely reassembled the TB and the air filter box and reconnected the MAF prior to reconnecting the battery cable and start up!
My friend broke his by moving the throttle plate and striped the plastic gears
donbrew Jan 9, 2015 08:07 AM
I saw them on eBay for $120.
Agpullen Jan 9, 2015 08:25 AM
I've seen a few for that price too, but would really like on here in AZ. There is a company in Tempe that has them. I have a 1978 Camaro that for the time being is my daily driver and I really don't want to push it too hard. So getting the HHR back up and running ASAP is a big priority at the moment. I'm just hoping I dont need a reflash, I don't know anyone who can do it or how much it'll cost.
Oldblue Jan 9, 2015 08:54 AM
Please reread my post #17
