Tire pressure sensor wigging out.
On my 2008 panel...I have a random tire pressure sensor that seems to shut off.. i thought it was probably just a connector, but i'm thinking it could be a bad transmitter in the valve stem unit. If i cycle through the DIC, i see no reading for the right rear tire. The tire is up on pressure so i know that's not it.
It hasn't annoyed me enough to take it to the dealer yet, but probably will this spring.
Just a heads up...no biggie.
Crafty, why can't one toss some run flats on any rim? I didn't think that a tire pressure monitoring system was essential for run flats. I guess it would tell you when your tire does lose pressure but I wouldn't have thought that a system was essential.
Well, I'd want to have the TPM just so I'd know if the tires went flat while I was going down the road, I guess. I suppose there'd be no reason not to install them if you kept an eye on them.
Wishful thinking, anyway...
Crafty, before buying run flat tires consider that the tire cost is high, it takes special machines to mount them, which may not be available when you need them, a flat tire must be trashed which means possibly replacing two expensive tires, which tire stores do not stock because they are expensive and rare. Say you decide to go skiing over the weekend and you drive up into the mountains to the resort having a flat on the way. No dealer has the machine to mount the tires in the boondocks, which does not matter since he does not have the two tires you need (safety requires replacing both tires on an axle if they have significant wear). And he will not mount an odd tire to get you by because it is a safety hazzard. So they load your car on a flat bed (two bucks a mile and no insurance coverage) and haul it back to the city where the dealer will be available on Monday to fix your car, when the tires come in from the distributor. No thanks.
.. IF I DIDN'T HAVE THAT $250.00 Crafty, before buying run flat tires consider that the tire cost is high, it takes special machines to mount them, which may not be available when you need them, a flat tire must be trashed which means possibly replacing two expensive tires, which tire stores do not stock because they are expensive and rare. Say you decide to go skiing over the weekend and you drive up into the mountains to the resort having a flat on the way. No dealer has the machine to mount the tires in the boondocks, which does not matter since he does not have the two tires you need (safety requires replacing both tires on an axle if they have significant wear). And he will not mount an odd tire to get you by because it is a safety hazzard. So they load your car on a flat bed (two bucks a mile and no insurance coverage) and haul it back to the city where the dealer will be available on Monday to fix your car, when the tires come in from the distributor. No thanks.
I notice there are some aftermarket sensors available that look pretty good.
