torque converter
I have a 2006 2.4 litre and have had a engine shake at acceleration !!!! After changing front axcles and doing brakes. then checking the rear bearings and replacing rear brakes. The only thing I can come up with now would be the Torque Converter !!!!!!! Any other suggestions !!!!!!!!
Is it more like a shudder? Like a clutch slip? I get that every now and then..be hard to take to dealer since u never know when it will show up,,,,is yours all the time or intermittent?
what speed does this happen? is it on take of from a stop or after crusing down the road on acceleration? The only time I have seen a Torque Converter cause a sudder is after the converter go's in to lock up at crusing speed.
Another thing to look at is the engine mounts, they can give you one heck of a shudder.
i changed my map sensor as i got a code but no difference. i have done frt brakes rear brakes frt axles checked rear bearings everything is fine. i am still getting the abs and t/c light and still shakes on take off then peters out !!!!!! frustrating and confuses
Did you clear the codes after the repairs were made ?
