Tpm
Old 01-10-2019, 07:47 PM
  #41
Technical Moderator
Did you think about mechanically checking the PSI?
donbrew is offline
Old 01-17-2019, 10:21 PM
  #42
Originally Posted by sleeper
Yep, & mine is at that point. Hope I didn't just jinx myself....
Well I jinxed myself...........
If you have 1 dead TPMS sensor the system can't complete a successful re-learn, imo.
I have a dead battery in 1 TPMS sensor. But I'm waiting till spring & plan to replace all 4 sensors with new tires.
sleeper is online now
Old 01-20-2019, 09:10 PM
  #43
BTW: What is the OE part number for our HHR TPMS wheel sensors ?
Old 01-20-2019, 09:20 PM
  #44
https://www.chevyhhr.net/forums/comm...-thread-48833/
(at the very bottom of page )
firemangeorge is offline
Old 01-20-2019, 09:34 PM
  #45
Thank You Kindly Sir. I looked thru that list, obviously not good enough tho..
- TPMS Sensor W/Rubber Valve Stem GM P/N - 25920615 (2008-2011) This Part # from 2013 is now Obsolete...........
Old 01-21-2019, 10:42 AM
  #46
2008, I came up with this
ACDelco 13598771 GM Original Equipment Tire Pressure Sensor TPMS Set of Four (4)
Amazon Amazon
Oldblue is offline
Old 01-21-2019, 08:24 PM
  #47
Blue- Thank You, those don't look anything like what I have now. I have these below. Seems your link is to a newer updated version, I think.
Below lists replacement part, but it doesn't replace my old part # ? I find this is for Steel rims only.....
  • Manufacturer: GM
  • Part Number: 13598771
  • Part: TPMS Sensor
  • Replaces: 13586335
Old 01-21-2019, 08:58 PM
  #48
Your part # links to TPMS for Steel rims, 2008
From GM Parts Direct gives part # 20923680TPMS Sensor
Part Number: 20923680
Product Notes:
Tire Pressure Indicator Sensor
All; Tire (QBV); Alum Whl (QP2); All non high-Perf apps prev servd w/met stem now servd w/rub stem; LT, LT Panel.
Per Vehicle: 1; Years: 2008-2008
Thank You Blue.
Old 01-22-2019, 11:45 AM
  #49
RockAuto has this listing , steel or aluminum rims, I googled the GM part number and viola
Oldblue is offline
Old 01-22-2019, 12:48 PM
  #50
Cat Man HHR's Avatar
https://www.ebay.com/itm/ACDelco-135...5.c10#viTabs_0
Cat Man HHR is offline
Quick Reply: Tpm
