TPMS : 2 sensors quit reporting at same time
I recently inflated my tires from 26 psi (been letting it go for awhile) up to 32 psi (my preferred pressure). A day later, the RF set off the monitor, and the LF followed within hours. A few days later, both still read nothing, but the rear sensors are still OK. Just a coincidence ? or is something going wrong with the read-out? I have eight wheels, both sets from 2009 panels, so I can't tell which wheels have received new sensors (I replaced two, 3 and 4 years ago). Seems odd that two would fail within a coupla hours of each other, doesn't it?
Are they showing actually nothing, or dashes?
They're just as likely to fail at the same instant as not. When mine failed, it would occasionally go dashes, but usually functioned properly. |
They both show dashes. If it is just the sensors, I might not replace them, since they're just a pain (and expense). Does the TPMS have to be functioning to pass the safety inspection, coming next month? I'm spending cubic dollars on a new home project right now, and I don't need more $ outlay, at this time.
Maybe someone who knows Texas law will chime in. Cali just has smog check every other year, not a safety inspection.
As long as the TPMS does not set a trouble code, you should pass inspection.
2 Attachment(s)
If it was the RCDLR none would be working. There are DTCs for the TPMS, they just don't cause CEL (because they are not related to emissions).
You need to know what you are doing with the code reader to get them. Each has a 2 digit hex number after it that tells the exact reason. Attachment 45660 |
Originally Posted by J W Davis
(Post 830081)
7 years; that's too often? How often do you change a watch battery?
So, now you get 12 years out of headlight bulbs? Hint: get the cheapest bulbs; the cooler they are the longer they last. My OE bulbs lasted 3-4 years, replaced with expensive "bright white" bulbs that lasted 6 months, back to the cheap "yellow" bulbs never did blow. And got 2 class-action checks from Sylvania for their false advertising life estimates. |
slight exaggeration of timescale
Originally Posted by donbrew
(Post 830176)
