TPMS relearn
Old Mar 27, 2026 | 10:02 PM
The turn signal lights weren't working?
Are the tire pressures reading ---? Message on the DIC? Did you try with the tool? You know releasing air does not work on all 2010?
Old Mar 28, 2026 | 03:43 PM
chaosdsm's Avatar
Was sitting in the car when I was trying, so I didn't see the turn signal. Tried it by releasing air, then with TPMS tool.
I think I'm going to try these:
Amazon Amazon
external TPMS sensors, they just replace the valve stem caps, and a set of 4 are cheaper than one AC Delco TPMS. Supposedly, they are "Compatible with GM branded vehicles manufactured after 2006", and only require the included tool (same one I already have) to activate.
Old Mar 28, 2026 | 06:49 PM
I have these in my 2011, they work and are inexpensive
https://ebay.us/m/fHa3WC
Old Mar 28, 2026 | 09:07 PM
chaosdsm's Avatar
Two reason's I'm going to try the ones I linked other than price:
1> They are external TPMS Sensors - so you don't have to break the seal on the tire, pull out the old sensor, put in the new sensor, re-seal tire... it's just swapping valve stem caps.
2> They have user replaceable batteries, so, in theory, just one purchase of sensors, then new batteries every few years.
Old Mar 29, 2026 | 07:59 AM
But then some kid likes that cool look for their bicycle and takes one or two. My dice valve caps I made disappeared while I was getting changed to go to my Friday night car show. It happens.
Keep us updated on these caps.
Old Mar 29, 2026 | 12:55 PM
chaosdsm's Avatar
That is a possibility, but because they are under constant air pressure, they have to be tightened with a wrench, so a little less likely to happen.
Old Mar 29, 2026 | 02:37 PM
? The valve stem doesn’t hold the air pressure in?I watched the entire video, I see the lock rings and orings to install.
seems like these will work
Old Mar 29, 2026 | 05:13 PM
Senior moment?
Old Mar 29, 2026 | 06:11 PM
Ci, senior! More just a lazy assumption of the facts, that’s why I watched the video! Learned something new.
HHR SS 3M...
Jan 26, 2025 11:46 AM
Gearhead1
Feb 24, 2022 09:11 PM
skyline26
Jul 15, 2013 09:34 PM
gbynum
Tires & Wheels
Oct 26, 2012 12:32 AM
BlackknighT
Aug 19, 2011 07:15 PM
